Pulsar PowerBook 180
Posté le: Sam 11 Juin 2005 Ã 13:59 Sujet du message: |
 _________________ MAC - PB Rev.D 12"/1.5 Ghz/512 mo DDR333/Geforce FX 5200 Go/HDD 60 Go 5400 tm/Combo/Wifi/BT // Mac OS X 10.4.2
Posté le: Sam 11 Juin 2005 Ã 19:33 Sujet du message: |
Je viens de trouver la solution... Je vais tester et je vous dirai si cela fonctionne.
Tiger Feature of the Day: Text-based Contacts Import in Address Book
In previous versions of Mac OS X, the Address Book application could only import vCards and LDIF (Lightweight Directory Interchange Format) files, severely limiting compatibility with third party email applications and giving rise to a cottage industry of custom contacts importers. In Tiger, Address Book has been updated to version 4.0 (from 3.1 in Panther). Among the new features is a new contacts importer that can import contacts from text files (in addition to vCards and LDIF files). These text files can be in tab-delimited or CSV (comma-separated values) format.
To test this feature, I exported my Windows-based Microsoft Outlook contacts list to various tab-delimited and CSV formats and then attempted to import them into Address Book in Tiger. You import text files by selecting the File menu, then Import, and then Text file. In the resulting File Open dialog, navigate to the location where you've stored the text file and select it, then click open.
I tested the four different text file formats and received the following results:
CSV (DOS format) - Text file import failure.
CSV (Windows format) - Text file import failure.
Tab-delimited (DOS format) - Text file import failure.
Tab-delimited (Windows format) - Text file import failure.
Convinced that the problem was Outlook and not Address Book, I then imported my Outlook contacts into Mozilla Thunderbird on Windows, and then exported them again to CSV and tab-delimited text files. I also exported the Thunderbird contacts as an LDIF file for testing purposes. I received the following results:
CSV - Brought up the Text File Import dialog, but had no idea how to handle the various fields.
Tab-delimited - Brought up the Text File Import dialog, but had no idea how to handle the various fields.
LDIF - Worked fine. Address Book noted that it was importing 81 new cards and all of the contact fields appeared to map correctly.
I've struggled with contacts importing on Mac OS X before, as evidenced by this article, and had hoped that the addition of text importing in Address Book in Tiger would make things easier. But that doesn't appear to be the case: I still need to use a third party tool to exchange data between Outlook and Tiger's Address Book. That's too bad, and it will make life a bit difficult for anyone that uses both Windows and the Mac.
http://www.internet-nexus.com/2005_04_17_archive.htm _________________ MAC - PB Rev.D 12"/1.5 Ghz/512 mo DDR333/Geforce FX 5200 Go/HDD 60 Go 5400 tm/Combo/Wifi/BT // Mac OS X 10.4.2
Posté le: Sam 11 Juin 2005 Ã 21:11 Sujet du message: |
Ca marche enfin mais la manip est fastidieuse...
Donc en gros, si tu veux transférer tes contacts OUTLOOK (PC) vers ton carnet d'adresse (MAC), il te faut exporter tes contacts en un fichier .LDIF.
Outlook ne gerant pas cette extension, il faut installer Mozilla Thunderbird, un autre client email pour PC. Importer ces contacts Outlook sur Thunderbird et exporter le tout au format LDIF.
Copie le fichier LDIF sur ta clé USB et importer ce fichier depuis le carnet d'adresse de ton MAC.
Ca marche mais c laborieux comme systeme ! Le changement de version VCARD avec Tiger (3.0) serait à l'origine de ce probleme qui n'en etait pas un sous Panther (2.1)... _________________ MAC - PB Rev.D 12"/1.5 Ghz/512 mo DDR333/Geforce FX 5200 Go/HDD 60 Go 5400 tm/Combo/Wifi/BT // Mac OS X 10.4.2
ONS99 PowerBook de Chêne
Posté le: Sam 11 Juin 2005 Ã 23:15 Sujet du message: |
Bizarre .
1) Comment se fait-il que tes vCards Outlook aient l'extension .msg alors que l'extension des vCards est .vcf sous MacOS ? Extension différente suivant la plateforme ? Bizarre pour une norme d'interopérabilité.
2) Changement de versions vCard dans le carnet d'adresses ? Il me semble pourtant que le carnet d'adresses de Panther offrait les mêmes choix en la matière que l'actuel carnet : 2.1 ou 3.0. Je ne peux pas en être sûr à 100% puisse que je n'ai pu Panther mais je ne pense pas me tromper.
Bref, bizarre… _________________ Éric
Posté le: Sam 11 Juin 2005 Ã 23:21 Sujet du message: |
C vraiment la galere !!
En plus, je ne trouve aucun programme qui permettrait d'eviter Thunderbird comme intermédiaire à Outlook et Carnet d'adresse ! _________________ MAC - PB Rev.D 12"/1.5 Ghz/512 mo DDR333/Geforce FX 5200 Go/HDD 60 Go 5400 tm/Combo/Wifi/BT // Mac OS X 10.4.2
